Help. New member here. Bought a used Bobcat 843B on CL a few months ago. Ran good when I bought it. Parked it and have started it up every few weeks to keep everything in good working order. About a week ago all I would get is a clicking when trying to start. Charged and tested the battery. Tried to jump the starter solenoid and it would not engage the starter. Replaced the starter solenoid and it fired right up after installing the new solenoid. After a few minutes of running it ran really rough. Would run fine at low idle but really rough when you put the coals to her (throttle up). Sounds like a fuel supply issue and I am replacing the fuel filter as we speak to see if that solves the problem. However, running rough is not my main problem right now. I can't even get it to start now. When I was fiddling around with the throttle issue the ignition switch was acting up. Sometimes it would turn the machine on, sometimes not. Almost like a loose wire or loose fuse. Work called so I had to leave it for a few days. I tried to start it yesterday and when I first turned the key on - guages worked, good voltage, lights, everything worked and it cranked up fine. I turned it off and tried to start it again. This time nothing - no guages, no lights, nothing. I know there is power getting to the starter because I can jump the starter solenoid and it tries to start the motor. Works fine when everything is cold. When the machine warms up, the ignition switch does not work. Both fuses are good. Is this a starter relay issue, or an ignition switch issue, or something entirely different? Anyone know how to troubleshoot either? I do have a manual for the machine from the previous owner and a wiring diagram, but the electrical troubleshooting chapter is not very helpful at all. I'm admittedly not very keen on electrical issues.
