262c cooling fan will stop and motor will get hot...
Does it have a thermo-fan setup? i wonder if it could be a bad sensor telling it to turn on
knogen
Unplug solenoid on fan motor . Should make fan run full speed. That will tell if it is electric problem.it will throw a code when you unplug it If it doesn't go full speed you have a hydraulic problem.most likely motor. Could be a sticking spool in solonid stem
