Hi I need to replace a tire on my 863 bobcat and my question is can I only buy one to put on or should you replace the tires in pairs. The old tires are wore down a good bit but they are not completely smooth yet I just blew a side wall on the one that needs fixed. Then my next question is can you run over the tire steel tracks and foam filled tires together or would they together be to heavy for the machine. Someone said I couldn't do that but I wanted to check with you guys first. How much weight does the foam filled tires add to the weight of the machine? Thanks for the help.
