Is a L600 rounder worth fixing?
1816case
I can buy for $1500. not running but engine is not stuck. Sat long time. carb is bad. worth fixing or is it somewhat reliable considering everything in good order?
foton
well you in todays market would not be out much, if parts are common why not if you can use it. of course I can not see what overall the wear is on it, sooo
cdmccul
I'm with foton. I don't think you can go wrong, given the rest of it is serviceable.
If you don't buy it, may I ask what part of the world it is in? :)
(I don't have a lot of cash sitting around, I'm only half serious)
1816case
Southern WI
cdmccul
Hrrrrrmmmmmm. If only my brother had a car trailer.
I'll let you know if I need more info. Thanks!
cdmccul
I'm only 1% able to. Ha! If it wasn't two states away.
Honestly, if it is in half decent shape, carb repair isn't hard work.
Ster1
I just replaced the Onan in a Rounder with a Harbor Freight engine. The owner loves it because it fits inside his chicken coop :)
Troy1ST
Which engine did you get and is it still working fine? Enough power? I found 18hp there but only 440cc compared to Onan 700cc.
