Coolant in engine oil
Jameshow04
I have a 2007 Bobcat s185. It had coolant in the engine oil so my son had the head checked and resurfaced and replaced the head gasket. It's been about a month or so and now there is coolant in the engine oil again. Wha else could cause this?
brdgbldr
I'm not positive, but I believe it is possible to have a gasket fail in the gear-case that could cause this. The water pump is attached to it.
Take a look at the parts catalog to see what I'm talking about:
What type of head gasket did you use? if composite, did you re-tension it after 6 - 10 hrs of run time?
