Thanks Jerry , If center hole is same this might work as I'll be getting all four. Anybody know if center hole is same?I have seen a bobcat rim on a '05 216 so the bolt circle is the same but I didn't pay much attention to the center hole. It looked odd because the bobcat wheel and tire were about 1 1/2 inches taller than the cat wheel on the same side. Must have been different profile tires. I measured it with a tape. could not be good for the chains. Others will know for sure.
I have a set of 12" Cat wheels I use on my 763. I don't know if the center hole is exactly the same size or a little larger. I didn't have to modify the Cat wheels to mount them on my 763.Thanks Jerry , If center hole is same this might work as I'll be getting all four. Anybody know if center hole is same?
Thanks for the info guysI have a set of 12" Cat wheels I use on my 763. I don't know if the center hole is exactly the same size or a little larger. I didn't have to modify the Cat wheels to mount them on my 763.
