Case SR200 Fuel gauge leds
Jim.butcher87
Hi, any help would be appreciated. Bought this 2012 case SR 200 and the fuel gauge LEDs as well as temperature gauge and I'm guessing oil temperature don't work as seen in the picture the hour meter works, I'm assuming this is a gauge problem since all three LED levels are not showing anything.
Thanks Jim
foton
if you can get it apart it might not hurt to look at it and see if there is a broken connection in there, if you had a repair manual you could look at the pins with a meter and see if you can see the resistance of the sensors., to verify which is bad the gauge or sensor.
J
Jim.butcher87
Yep that is my next plan! I did try to take it apart, the unit is all siliconed together, I think I'll try again, but the first time I did it of course I ended up, stabbing the palm of my hand with a screwdriver when it slipped
haymaker
I usually stab myself before I start the job to get that out of the way before my hands are dirty.
