Bobcat 873 help
T
When I turn the key to start the machine it spins over for 1 or 2 seconds and stop (!) Light comes on. Then I tried to jump the solenoid on the start just spins over. And I tried manually with the fuel shut off
polishpete
THE BLACK RELAY FOR FUEL IS NO GOOD OR ITS NOT HAVING GOOD CONTACT TRY
TO BY PASS IT WITH A JUMPER TURNS OVER FOR 2 TIMES THATS IT RIGHT U JUMP THE STARTER
SPINS NO START RIGHT
T
Yes. I've swapped relays. I'll dig it to the wiring and see if there's a broken wire or something on the back side
873skid
I have a 873 with 2 speed switch but it didn't come with the 2 speed You might check that it came with the 2 speed.
