Bobcat 773G Auxiliary Hydraulics
Feedbag
Hello, I'm running a 773G with auxiliary hydraulics that puts out 16.7 GPM. I'm looking at a tiller that needs 18 GPM to operate according to it's spec sheet. Would anyone know - if I was to get this tiller, would I be able to run it with my hydraulic flow rate? I'm thinking I might be able to, but it wouldn't be able to operate at it's peak performance. It would only be used for tilling my garden. Thank you....
foton
I would think it will work in sand or a loose soil ,but I will question if it will run well enough in heavy clay soils, of course the engine will have to run at a higher rpm to get the flow to max. out. so roll the dice and good luck.
