I'd let a dealer look at, the code maybe a red herring. All sensors run on a sensor circuit. One sensor can go and throw the system voltage off. The controller doesn't know what to make of the voltage signal and guesses the problem. It's no always right. A bad oil pressure sensor can throw a hydraulic code because the controller is confused for example. Not saying its not cut and dry a bad hydraulic temp sensor, but I don't want to tell you with 100% certainity it is.M0721 - Hydraulic Oil Temperature Out Of Range High. Hydraulic temperature shows - 40 ?!?! This is a misunderstanding between the sensor and gateway controller. Sounds like a faulty sensor.
It was mice nesting/chewing on wires. $1300 later it runs like new again. ._.I'd let a dealer look at, the code maybe a red herring. All sensors run on a sensor circuit. One sensor can go and throw the system voltage off. The controller doesn't know what to make of the voltage signal and guesses the problem. It's no always right. A bad oil pressure sensor can throw a hydraulic code because the controller is confused for example. Not saying its not cut and dry a bad hydraulic temp sensor, but I don't want to tell you with 100% certainity it is.
Sucks it was something like that. My guess for that price it got a new harness.It was mice nesting/chewing on wires. $1300 later it runs like new again. ._.
